Missing Parts - 47 ohm resistors - Printable Version
+--- Thread: Missing Parts - 47 ohm resistors (/showthread.php?tid=666)
Pages: 1 2
RE: Missing Parts - 47 ohm resistors - Einar - 2014-08-18
I thought this a bit strange. After >40 years of squinting at color codes the number 47 seemed familiar to me.
So I looked in my resistor rack and found 47Ohm 1%. And I this is a standard assortment rack.
Then I checked with one of my preferred suppliers.
Axial leaded, 50Ohm, <250mW, 1% or better: 6 products found.
Axial leaded, 47Ohm, <250mW, 1% or better: 6 products found.
For a BO kit either you get just that: a kit. And it probably could be in the build instructions that if you don't find the exact value, use the closest there is in the kit.
For most of those buying the components, Anders comment above is good reading.
When designing something I don't specify a % on the value unless it need to be. Even if that have become the standard component. That is a way of telling that it is a chosen value rather than an exact calculated value. Again: ref. Anders post.
If parachuted into the most remote corner of the world to build a kit, and having to beg the parts from the local radio shaman, you would most likely be getting E24 parts.
RE: Missing Parts - 47 ohm resistors - RichoAnd - 2014-08-18
Even if a component is not standardized with an international standard, it may well be standard if sufficiently widespread.
E24 series is available across Europe, available in 1% metallized, and is cheap
Whatever you ask for 5%, you risk getting 30-40 year old components that are difficult to solder on.
I use mainly values ​​of the E12 series, but expect to use 1%, not because it's necessary, but because they are cheap enough to have lying around.
http://www.logwell.com/tech/components/resistor_values.html
