internet speed - Printable Version
+--- Thread: internet speed (/showthread.php?tid=839)
Pages: 1 2
RE: internet speed - cutty - 2019-10-25
(2019-10-25, 14:15)Axley Wrote: Is there any delay when watching your own signals btw?
Not when watching on your local GUI controller signals. You see everything as it is received ... now, what you see on the 'website' signal displays are not everything seen be the controller.. not every signal is sent by the controller, and eventually the server onkly selects the best valid channel for processing... so the delay between controller and web display will range between 1.2 and perhaps 8 seconds.
RE: internet speed - aprwx - 2021-03-10
Just to update my original issue (now years old). I believe the issue ended up being a bad ethernet cable. For whatever reason, even though the internet connection worked through the cable, most of the strikes detected would not get logged until I used a different ethernet cable.
