Looking to setup station in South Africa - Printable Version +- Blitzortung.org Forum (https://forum.blitzortung.org/mybb) +-- Forum: Public Forums (https://forum.blitzortung.org/mybb/forumdisplay.php?fid=29) +--- Forum: General Discussion (https://forum.blitzortung.org/mybb/forumdisplay.php?fid=31) +--- Thread: Looking to setup station in South Africa (/showthread.php?tid=978) |
RE: Looking to setup station in South Africa - rogerpaulthompson - 2015-06-19 (2015-06-19, 07:38)Knickohr Wrote: You sending a lot of disturbers : Hi Thomas, Not sure what that is. I actually have much larger disturbers as well. I'll try turn down the gain manually - let's see what happens, my station might go totally quiet then ![]() If I don't have too much success with this station I could consider installation at another location down in the Eastern Cape along the coast, I might have better success down there... Roger RE: Looking to setup station in South Africa - Knickohr - 2015-06-19 That doesn't help ! You only separate the disturbers, not the strokes ![]() Try to locate it, try shielding the ferrite. Try to find a sweet spot, maybe rotating the antennas work. Thomas RE: Looking to setup station in South Africa - Steph - 2015-06-19 (2015-06-19, 07:38)Knickohr Wrote: Whats this ? An electric fence ? Since both singals are in phase and in the same polarisation, possibly it's coming via the power supply / mains. You can turn one antenna 180°. If it persists, you need to put a choke between the controller and the psu. I had the same problem here, my 230V-line is very noisy and the PSU does not decouple these frequencies. RE: Looking to setup station in South Africa - Louwrens - 2015-07-20 (2014-12-05, 07:37)rogerpaulthompson Wrote: Hi all, Hi Roger I am Louw and would like to do the same. I am in Port Elizabeth. I have tried to get one of the new green I think its called receivers but haven't heard a thing from them. I would like to hear from you if you get info from them. Louw. If you want to contact me use this e-mail:ferreirasl@telkomsa.net RE: Looking to setup station in South Africa - Jacquesvw - 2016-03-01 Hi, I have a pre-assembled system Red for sale to any South African. Includes both amplifiers and an H-field antenna. RE: Looking to setup station in South Africa - rogerpaulthompson - 2016-03-01 (2016-03-01, 13:38)Jacquesvw Wrote: Hi, Hi Jacques. Sure, Ill take it. I'll PM you ... Roger |
