Self-built Blue Basic (PCB 22.2 + 23.1): accepted in the network, and how to flash a - Printable Version
+--- Thread: Self-built Blue Basic (PCB 22.2 + 23.1): accepted in the network, and how to flash a (/showthread.php?tid=4411)
Self-built Blue Basic (PCB 22.2 + 23.1): accepted in the network, and how to flash a - LDev - 2026-11-27
Hello everyone,
I would like to join the network with a new station in Coriano (RN), Italy. Since very few detectors are available for 2026, I am planning to build a Blue Basic detector myself from the files published at limaps.org/Hardware (PCB 22.2 main board and PCB 23.1 H-field preamplifier).
My plan is to have the boards manufactured and assembled by a PCB service using the published Gerber, BOM and pick-and-place files, strictly following the BOM without any changes to the components, especially in the amplifier section. I would then solder the through-hole parts and connect two ferrite rod antennas myself.
Before ordering, I have a few questions:
1. Are self-built PCB 22.2 boards accepted in the network, or should I ask for approval first?
2. How do I flash the initial firmware on a blank STM32? Is it the usual USB DFU procedure with the BOOT0 button, and which firmware file should I use for a board that has never been programmed?
3. In the BOM, many passive components have only a value and a package. Are there any special requirements (tolerance, dielectric type, specific manufacturers) for the parts in the amplifier and filter section?
4. Which GNSS antenna do you recommend for the MAX-M10S, and which connector/cable should I use for the GPS input?
My station would be on the rooftop of a tall building.
Thank you very much for your work on this project.
Best regards
