New Project Blue request form?
(2020-06-20, 21:44)7rst1 Wrote: I live in the outskirts of a small village, so I presume RF is no issue here. I also enjoy tinkering with electronics, maps and lightning, so thought receiving a detector could be a healthy mix of all of them! However, looking at the stats above, you don't seem to need one here, which I totally understand when seeing the stats you've given. I have nothing more to add, so case closed I guess.
Thanks for the responses anywaysSmile
7rst1, it looks like i came across wrong, apologies. I was not suggesting that your area is well covered, but rather that strokes are being picked up by stations much further away and displayed on the map. If you look closely at the map, you only see a couple of lines from stations in Norway.
I am happy to see you already registered on the list to order a station. Patience, your name to order will also come up, just like ours did.
Regards.
Today I signed up for a blue kit, and only now realized how big the cue is! In Brazil (5th largest country in the world) there are only 3 stations, in a region far from mine. I'm pitching this project to the agrisciences company I work for. So, I was wondering how much improvement would be country/region-wise installing 2-3 stations within a 50-300km radius?
