(2020-10-31, 12:46)yVega Wrote: User name: yVega
User number: 2207
Station number: ?
Region: Europe
I'm online now, how can I get the associated station number?
Have you registered your station on the owner's page?  If in fact your station has sent signals to the server, it should be recognized, and on your controller page, upper right, should show a number, or instruction link to register.  under 'tracker' status, should show a server connection and address.... the system WILL not recognize you IF YOU HAVE NOT sent signals.
User number: 2207
Station number: ?
Region: Europe
Have you registered your station on the owner's page?  If in fact your station has sent signals to the server, it should be recognized, and on your controller page, upper right, should show a number, or instruction link to register.  under 'tracker' status, should show a server connection and address.... the system WILL not recognize you IF YOU HAVE NOT sent signals.  AND and the system WON'T become active at all unless good GPS is noted, and 1PPS signal syncs.
User number: 2207
Station number: ?
Region: Europe
Sorry, I had activated the system with network/gps online only...
where I can read the Processor-ID for insert then in owner page?
and where can I read the sequences of operations I have to do?
I would not forget anything else
[Image: 4178719.png]2855
Stations: 2855
(2020-10-31, 14:52)yVega Wrote: where I can read the Processor-ID for insert then in owner page?
Please see https://forum.blitzortung.org/showthread...d#pid20250
Ok, thanks for your patient, it's all associated now.. tomorrow I'll position better primary antenna and gps antenna
Stations: 2855
yVega, what is your station number so we can have a look at it and move you to Participant status if you are sending signals.
Sorry, I'm updating request:
User name: yVega
User number: 2207
Station number: 2855
Region: Europe
Stations: 2855
User Name: Dave:WD7K
User Number: 1780
Station Number: 2283
Region: North America
Station listed, Was receiving data. No longer receiving data.
You won't need to insert processor ID... if you have sent signals, and server has activated your station, the server knows it already, assuming it is associated with your user ID.  What you WILL have to do is input the correct antenna configuration, and, if you want it's data displayed on maps, etc, make sure "ANON" is "NO"...
You probably won't need to insert processor ID... unless you've taken over a station previously assigned to someone else,... if you have sent signals, and server has activated your station, the server knows it already, assuming it is associated with your user ID.  What you WILL have to do is input the correct antenna configuration, and, if you want its data displayed on maps, etc, make sure "ANON" is "NO"...
