Question about the "shift" value in System BLUE raw signal data
I am a graduate student at Chiba University, Japan. I am analyzing raw H-field waveforms from station 3005 (System BLUE, main board Ver 19.5) recorded on 10 July 2025.
According to the UDP format description, the 12-bit samples are sent as 8 bits, and "shift" is the lowest value at which all samples of the record fit. So the original value should be (8-bit value) x 2^shift.
However, our data do not seem to follow this:
1. Records of nearby lightning (within 30 km) are almost all shift 0, and many of them are saturated at 0 or 255. With the lowest-fitting rule, a larger shift should have been chosen.
2. The background noise before the trigger becomes exactly 4 times larger for each shift step, when read as (8-bit value) x 2^shift.
3. Read in the same way, the product (distance x time integral of the field) increases strongly with distance. If we additionally divide by 4^shift, it becomes almost independent of distance.
Could you tell me:
- Is there any automatic, per-record gain change in System BLUE, in addition to the amp settings?
- If the station is in automatic gain mode, is the gain adjustment related to the shift value?
- If so, how should the recorded values be converted to a common scale?
I attached three figures (a saturated record, the shift statistics, and the distance comparison).
Thank you very much for your help.
Best regards,
Tenma Hara
couple of things.
3005 is one of many operated by shonan/etc. in university areas.
this discussion should probably belong in the 'operator's' non-public forum.
in order to access that forum, a user (the owner) must be logged in.
Second
before you make any conclusions or observations regarding what you see from or about 3005 you are using old, outdated firmware.
That system MUST be upgraded from the obsolete 9.4 version to the latest stable version.
You might pass that info up the line to the proper authority, as there are numerous systems owned by the same entity.
https://docs.lightningmaps.org/station-o.../firmware/
Firmware 11.0b3 (2025-03-03) - Beta firmware  Even though coded as beta, it's the version to use.
just make sure you download the version for BLUE systems
Good start, however, as the grad student, as part of the research might be to figure out why the data works as it does. Smile
Users browsing this thread: THara_Chiba, 1 Invisible User(s), 2 Guest(s)
