(2016-09-13, 18:12)RichoAnd Wrote: Minor difference if any
Richo if so, what do you suggest between those two. I was trying to make a loop for my system blue and i m a lit bit lost.
Simple loop or mobius (with or without trafo? )
I m asking cause i just have started to make a 38cm brake pipe mobius with trafo as in your example above and right now i m making my first windings.
(2016-09-13, 19:38)RichoAnd Wrote: 38cm "brake pibe" appears simple and robust, and is excellent for outdoor use
/Richo
So i shall continue my windings... 30 only left...
Ah. One more question... About the inner core should i prefer 2,5mm copper wire? Ι had plenty of 1,5mm available.
Should i use it or not?
Thanks in advance
I have started making the H field Copper tube Loop antenna shown in your mini guide and also from http://users.skynet.be/DanielV37/Project...m#Hardware. I have produced 3D print files for the top & bottom Junctions from the drawings on that site and have published these files at http://www.thingiverse.com/thing:1713141 . I have included attribution to the design as best I could find reference. Can you have a quick look at this url and advise if any further attribution is needed.
thanks
Barry (Australia)
Have a lot of suggestions for changes - water intrusion is a challenge
By the way - time has run from this antenna - it is too large, and intended for System GREEN
Make it of brake tube 5-6 mm and a diameter of ~ 40cm
Most effective is the "Möbius" with transformer
Richo,
thanks for your earlier advice. I have just commissioned by System Blue (ID=1631) and as per your suggestion I have built a paired 38cm diam Copper Pipe loop (6mm air condition tube) with 50 turn Toroid Ferrite Transformer. After a false start with the ethernet wiring and then playing with the gain and thresholds I think it is performing quite well (noise floor about 19mV & effective detection ratios compare well to other stations in the area). I didn't worry about O ring seals at this point I will use silicon sealant later to keep moisture out (but it won't stop the ants !!)
For others wanting 3d print the top & bottom brackets (or to look at more pics to seed their own designs) I have put them at http://www.thingiverse.com/thing:1792866
thanks
Barry (Australia)
thanks
Barry (Australia)
For a multi turns loop with 25m (1.5 diamater) long copper wire we have many possibilities between diameter/number of turns.
Is there an optimum: diameter 1000mm, 3 turns or diameter 380mm, 20 turns as show in the guide or can we build any diameter/turns (inductance is an issue ?) ?
Size of the signal is proportional to the total area of the loop
Read my "mini-guide" about what is necessary
Larger antennas can cause problems.
/Richo
