Threads: 9
(2015-04-29, 16:28)Benedict.Smith Wrote: (2015-04-29, 07:08)Tobi Wrote: The Tapatalk advert has to be removed via editing the source code, but that has already been done over 24h ago.
Thanks,
This morning when I logged in it was still coming up, however it appears to be gone now, perhaps it was being cached somewhere.
Ben.
Looks like I spoke too soon!!!
i have just done a full re-start of my IPad and cleared all the browser history etc, the blasted Tapatalk popup is still there, please have another look and try to kill this obnoxious piece of spam once and for all.
RED Station: 878, Flightradar24: F-EGLF1, Open Glider Network: Aldersht2, PlanePlotter: M7.
Stations: 878
Threads: 11
(2015-04-29, 18:57)Benedict.Smith Wrote: (2015-04-29, 16:28)Benedict.Smith Wrote: (2015-04-29, 07:08)Tobi Wrote: The Tapatalk advert has to be removed via editing the source code, but that has already been done over 24h ago.
Thanks,
Ben.
common, keep cool, it's a free service and Tobi/Egon will handle it once they have some spare time. Remember it's a hobby for them and they already have quite some things to do with server issues. If that add is TOOOOO much, just stop using tapatalk till it is solved and use you safari browser on your iPad, ain't such a bad way to surf on that device
Threads: 9
(2015-04-29, 19:38)Eric.Wouters Wrote: (2015-04-29, 18:57)Benedict.Smith Wrote: (2015-04-29, 16:28)Benedict.Smith Wrote: (2015-04-29, 07:08)Tobi Wrote: The Tapatalk advert has to be removed via editing the source code, but that has already been done over 24h ago.
Thanks,
Ben.
common, keep cool, it's a free service and Tobi/Egon will handle it once they have some spare time. Remember it's a hobby for them and they already have quite some things to do with server issues. If that add is TOOOOO much, just stop using tapatalk till it is solved and use you safari browser on your iPad, ain't such a bad way to surf on that device The thing is I DONT use Tapatalk, but every time I go to the forum on Safari I have to click through a fucking Tapatalk full page advert before I can get to the forum. I would NEVER use Tapatalk as I consider them to be the lowest form of scum due to their intrusive advertising, all I want is to be able to reed the forum without SPAM.....
Ben.
Stations: 878
Threads: 17
I just logged into my account using Safari and had no problems at all nor did I see any advertisements for Tapatalk. I am running in the USA and on a Windows based system so that may be the difference. Not sure why you are seeing Tapatalk advert but I am sure Tobi will be, or already is, working on the issue.
Have you tried logging in on another computer?
Best of luck and please, keep your cool. I understand you frustration but please don't take it out on the developers or admins...
Don - W7DRM - Emmett, Idaho - U.S.A. --- Blitzortung Station: 808 --- FlightRadar24 ID: F-KRNO2
Davis Wireless VP2, WD 10.37S70, StartWatch, VirtualVP, VPLive, Win10 Pro
Stations: 808
Threads: 9
(2015-04-29, 20:35)W3DRM Wrote: I just logged into my account using Safari and had no problems at all nor did I see any advertisements for Tapatalk. I am running in the USA and on a Windows based system so that may be the difference. Not sure why you are seeing Tapatalk advert but I am sure Tobi will be, or already is, working on the issue.
Best of luck and please, keep your cool. I understand you frustration but please don't take it out on the developers or admins... You won't see this on a Windows pc, it is specific to mobile devices and possibly only Ios, I don't know if it affects Android users.
This happened once before and Tobi managed to disable it at the server end, unfortunately with the recent changes it has re-appeared.
Ben.
Stations: 878
Threads: 78
Please calm down Ben.
After investigating the cause of the banner once again in the plugin code, I found it and removed it (I hope). There's no other way to deactivate it. However, I can not guarantee to put any more time and energy in this if it reappears in the future. Just tell me if you have better and/or more easy solution.
There are a several users which use Tapatalk, I've already seen more online of them as other users. No other user seems to have a problem with the banner so far, as it will only be shown once and will never appear for some longer time after closing it.
Threads: 5
New forums look great! Nice work.
Threads: 11
hi tobi,
nice look and feel. great.
thanks for doing this upgrade.
is there anywhere a "mark all read" button, which i have maybe overseen ?
// hans
Threads: 9
2015-04-30, 19:27
(This post was last modified: 2015-04-30, 19:28 by Benedict.Smith.)
(2015-04-30, 19:24)hans.mayer Wrote: hi tobi,
// hans Forum main page, right at the bottom, mark all forums read.
Stations: 878
Forum Look and sounds are really superb.
