Blue system antenna
(2016-06-05, 22:37)starlord Wrote: yes but that means, the anntennas could be much much smaller for the short range stations, in Germany as example...
smaller antenna = easyer to install cheaper because lesser material...
You are completely right. In such high density regions you can use a simple E-field antenna or small H-field ferrites or loops.
