Blue System Ground Point
Hello from Greece.
I just setup my new fifth station (system blue)
I want to ask if there is any ground point for system blue.
My old red system was performing much better when i ground it and i want to test it also in system blue..
Thanks in advance...
Not a connector as RED - you also find out Smile
I prefer a heavy point as F-Plug or SMA-Plug
I tested while waiting for an answer and it works fine....
CAse closed... Thanks for your time!!!
The ground can be connected to the following point.
This point has been reserved for it.
(2016-06-09, 22:32)Egon Wrote: The ground can be connected to the following point.
Thanks Egon.. I will make a hole today and make an external ground point through that.....
Smile
