Threads: 45
Threads: 65
2017-11-07, 03:48
(This post was last modified: 2017-11-07, 03:49 by cutty.)
what do you folks think? Have we about wrestled 'efficiency' around enough to 'close the thread'.. getting quite long,
Threads: 6
Supporting the first station in India 1974Stations:
Threads: 16
Since efficiency is a moving target and affected by so many variables, yes please close.
Threads: 7
So far, classification of signal has to be done by "hand". There is no automatic signal classifier and I doubt that it will be possible with the limited amount of manpower available to do it. But you can use what is available, for example in the controller panel on life signal, you can tick the box at the right hand lower corner labelled "noise floor". This will give you the untriggered signals, i.e. noise (with an occasional real signal thrown in) and you can form your opinion on what to do to eliminate it.
Threads: 6
(2017-11-10, 09:51)pasense Wrote: So far, classification of signal has to be done by "hand". There is no automatic signal classifier and I doubt that it will be possible with the limited amount of manpower available to do it.
I can get the stroke data from the server, but from where can I get all the signal data to be able to develop something (not sure if I can  ). Side condition: "my station" gets shipped to India next week, so I do not even have raw data locally anymore.
Threads: 65
2017-11-12, 03:16
(This post was last modified: 2017-11-12, 03:17 by cutty.)
(2017-11-11, 21:38)micha.d Wrote: I can get the stroke data from the server, but from where can I get all the signal data to be able to develop something (not sure if I can ). Side condition: "my station" gets shipped to India next week, so I do not even have raw data locally anymore. Michaud ... you should post this inquiry on the INTERNAL forums... such information should not be on public, and if a response is given here it may be edited or deleted depending on its content..
Thanks!
Cheers! Mike
Threads: 18
As there is no lilghtining all the measures are zero, yet stations are still sending 1000's of signals/hour. This can really only be local noise. We could rename "Effciency" to "Waste" and invert the calculation trapping the divide by zero problem to return 100%. Trouble is everyone above is 100% wasteful which, while technically correct, isn't useful. Is there some way to have a meaningful "Waste" value when the Used count is zero?
Maybe an "allowable noise" number? (<Sent> - <allowance>)/<sent> trouble is if your under allowance you end up with a negative "waste".
Ideas?
Threads: 9
(2017-11-24, 02:52)allsorts Wrote: Today there is no lighting activity in Europe to speak of (the Europe static map had a count of 7 (seven) a moment ago). My station sample produced this:
Ideas?
(I think therefore I am!)
Since Ten o'clock yesterday?
Having said that! Even if there is lightning in Europe it is probably not at a very high level. So, one has to ask:-
WHY are all these stations sending all these signals to the server?  (I am! Therefore, it must be so!)
Kindest regards,
Brian.
Threads: 7
2017-11-24, 07:57
(This post was last modified: 2017-11-24, 08:00 by pasense.)
