2019-03-29, 21:46 (This post was last modified: 2019-03-29, 21:48 by mwaters.)
(2019-03-29, 20:24)Dale.Reid Wrote: What does Mike mean by the lightning slider removing all but the most recent strikes?
I'm not sure what the lightning slider even is?
Dale
Hi Dale,
Just click the little menu icon, and you will see all the options drop down in a box. There are checkboxes to enable or disable several options, and each checkbox has a little slider to the left that can be dragged left or right.
Now about suggestions.
I am waiting for station lines so much.
Will be cool if i can go to the station page when click on its icon/sign.
Also be cool if i can see simple information about lightning strike by clicking on its sign.
Anyway thank you a lot for working at that cool map.
Some of the bugs can not easily be fixed because maxbox does not always work properly on all (older) devices.
The fact that the counters sometimes disappear is because stations or the current strikes are drawn over them. I will assign the counters to the top level.
The green lines I'm just trying to insert just like some other features.
(2019-03-30, 07:39)Egon Wrote: Some of the bugs can not easily be fixed because maxbox does not always work properly on all (older) devices.
Egon, thank you very much for the green lines on the new map! I observed that my green lines, pointing towards Australia, heading still to the east, and also from the Hawaiian Station 993! On the old fixed map this is alright and the only way to do it, but maybe you could fix this issue on the new map?
2019-04-03, 00:49 (This post was last modified: 2019-04-03, 11:05 by Vladimir.)
Also I again say Thanks and Respects to Egon and team of developers!
About bugs and lines defects. Think it's just under construction. Also be great if stations that registered the stroke were highlighted And sounds of strokes from whole map be fixed too ^^
Also I noticed a couple of flaws. 1) Defect with map + strange white|grey lines 2) Sometimes station lines don't occur (probably it's my fault, coz shit PC (which cant to process the data)).
Screenshots:
