Threads: 0
(2019-02-19, 22:34)dupreezd Wrote: (2019-02-19, 21:45)Blitzfeuer Wrote: (2019-02-19, 20:48)Egon Wrote: Dear Blitzfeuer,
station 1863 is not assigned to a user!
Insert the processor ID in the "Assign a new station: (Processor-ID)" field.
Egon
Dear Egon,
Every time I have inserted such as the station number "1863" it has immediately disappeared.
Mayhaps the "Processor-ID" is not the station number at all, but rather my "User ID"?
Or mayhaps an obscure number such as that of a CPU "processor ID"?
Confused, but still trying to understand...what specifically is the mysterious "processor ID?
Blitzfeuer Blitzfeuer, go here http://en.blitzortung.org/login.php and logon. Then assign a new station.
Regards
Dries
Hi Dries, thanks for the graphic -- it is something I have never seen before. Even just now I logged in again using the DE-language link you gave me, and it just shows the info I have already unsuccessfully entered, with no view corresponding to your graphic. So a "processor ID" is really a "device ID" without the dashes. Great, but how does one get the view you graciously presented that applies to me, User 1546, station 1863 -- simply by logging in?
Threads: 5
(2019-02-20, 19:23)Blitzfeuer Wrote: (2019-02-19, 22:34)dupreezd Wrote: (2019-02-19, 21:45)Blitzfeuer Wrote: (2019-02-19, 20:48)Egon Wrote: Dear Blitzfeuer,
Egon
Dear Egon,
Regards
Dries
Log in to your controller (the one that you build) . Then on the Status page, about half way down, you will see the it.
Dries
Threads: 55
Egon
Dear Egon,
Regards
Dries
I have done it for you!
Threads: 1
2019-04-15, 19:15
(This post was last modified: 2019-04-15, 19:16 by 1_i-mail.ru.)
1_i-mail.ru
2426
Europe
station not listed
Threads: 55
Threads: 0
user name = phobia/1883
station number = 2428
region = Australia/New South Wales
station not in station list on either site & not 'participant' on forum
Threads: 55
We have not received any signal from the station yet. No region has been assigned yet because no position has been received yet.
Threads: 0
(2019-04-18, 19:52)Egon Wrote: We have not received any signal from the station yet. No region has been assigned yet because no position has been received yet.
Yeah, I’ve not got a GPS antenna yet. Can I get participant status on the forums for some assistance with antenna designs?
Threads: 45
2019-04-18, 20:34
(This post was last modified: 2019-04-18, 20:35 by mwaters.)
AFAIK, the only way that anyone ever received participant status was after they started sending signals to the BT servers. Sorry.
A GPS antenna and an E-field probe should do that for you, provided that you have close enough strikes (the E-field probe is not sensitive enough to receive distant strikes). Otherwise, one or two 4-turn wire loops 1m in diameter should get you started as easily and inexpensively as is possible.
Threads: 0
Station not listed
User name: Zoran.Dragic
Station number: 727
User number: 623
Europe / Croatia
