Threads: 66
2019-06-26, 15:47
(This post was last modified: 2019-06-26, 15:58 by cutty.)
(2019-06-26, 03:24)bwreed Wrote: User Name: BWREED
Station Number: 2515
Region... North America
User ID: 1939. All station info is correct. Anony = N. Station does show on LightningMaps.org but not on Blitzortung. Station details on LightningMaps does not show station as active though it is recording strikes and sending the good ones. TIA
Brad
I can find you as a station operator on Lightninmaps, as 2526/19*39 ..but cannot find you as a station. I also cannot receive any signals from 2515 on the Sferics.,US signals page... which means 2515 does not exist on the BLITZORTUNG station database... examine this:
On your Blitzortung station operator's page, station setup, make sure you've entered the correct device ID... check against your controller GUI status page:
IF the DEVICE IDs match,(no dashes) and"N" is entered, do nothing..this is an issue for EGON.
If it doesn't match your operator's page (no dashes)
then that's probably the reason, --The server isn't recognizing you.
(gui will show dashes ,Station Config page no dashes)
IF That's the case, you need to delete the improper station...
Scroll down a bit... check delete and save
Then scroll back to the top, and register a new station device, and save... you'll probably get a new station number, also...
![[Image: 25154.jpg]](https://sferics.us/2515/25154.jpg)
The ONLY Wyoming station I can find listed is 2526, Cheyenne.
(2019-06-26, 15:47)cutty Wrote: (2019-06-26, 03:24)bwreed Wrote: User Name: BWREED
Brad
![[Image: 25151.jpg]](https://sferics.us/2515/25151.jpg)
![[Image: 25152.jpg]](https://sferics.us/2515/25152.jpg)
IF the DEVICE IDs match,(no dashes) and"N" is entered,do nothing..this is an issue for EGON.
![[Image: 25153.jpg]](https://sferics.us/2515/25153.jpg)
Thanks Mike. The Device and Processor IDs MATCH. When I login on LightningMaps and pull up my station info it displays:
Here you can find statistics of the TOA lightning detection station Hulett. - Id: 2515
- Firmware: 0.0
- Controller: 19.5
- Amplifier: H1 / E1
- Antenna 1: Loop, diameter=707mm, windings=4
- Antenna 4: Electric field, length=50mm
- Comment: Testing
General statistics of the last hour - Station active: no
- Last active: 12.6 minutes ago
- Last update: 12.6 minutes ago
- Last detected stroke: None
- Last signal: -
So they think the station exists and the info is correct. However, the station does not list on LightningMaps nor on BO. My guess is it's an EGON problem to solve. Do I need to do anything to make him aware???
Thanks again for your help.
Brad
Threads: 66
Brad...
Check your email for update..
Threads: 55
I am sorry, but I am not receiving any signals from Station 2015 on the server for Region 3. As long as no signals have been received, the station will not be displayed either as active nor as inactive.
I would connect the station for testing to another network, perhaps the UDP package on port 8307 does not come through.
(2019-06-27, 16:23)Egon Wrote: I am sorry, but I am not receiving any signals from Station 2015 on the server for Region 3. As long as no signals have been received, the station will not be displayed either as active nor as inactive.
Don't know if it is a typo but the station is 2515 not 2015. Brad
Threads: 0
user name = stevecollier
station number = 2302
region = North America
station continually flips as active between old location "Rockaway" and current location "Oakland." Same signals shown on both station statistics page. Station shows up on blitzortung.org but not lightningmaps.org.
Threads: 4
User Name: photinos
Station Number: 2556.
Region: North America
Forum operator status not upgraded.
Threads: 66
(2019-07-14, 17:23)photinos Wrote: User Name: photinos
Upgraded
Threads: 0
user name = geofabryka
station number = 2557
region = Europe
Thank you
Threads: 2
Username: vedrin
Station id: 2497
Region: Europe
Thanks!
