Threads: 15
2021-01-19, 10:07
(This post was last modified: 2021-01-19, 10:08 by Toxic.)
Hi there.
just looking at the UK station list here:
https://www.blitzortung.org/en/station_l...t_rows=100
I noticed a number of stations are listed as UK Country but 2-4 times in different Regions. is this a known bug?
Threads: 66
2021-01-19, 13:19
(This post was last modified: 2021-01-19, 13:27 by cutty.)
(2021-01-19, 10:07)Toxic Wrote: Hi there.
Some Stations are reporting in support of multiple regions. NOT a bug.
This is deliberate. This is assigned by the main servers. Also before someone asks again... the numbers for such stations are reported per/region, not a 'total' of 'all' signals from that station. Such stations must be checked by 'region', rather than just requesting a station number, expecting 'totals', etc.
Threads: 15
(2021-01-19, 13:19)cutty Wrote: (2021-01-19, 10:07)Toxic Wrote: Hi there.
Thanks for the update.
Threads: 0
2021-04-26, 04:46
(This post was last modified: 2021-04-26, 11:51 by cutty.
Edit Reason: updated information
Hi
User - Sareme
Station - 2365
Area - Europe Cyprus
Fault - Station Active: Yes/no reception
Receiving signals OK but all parameters are at 0 on the network stats page. Last signal received 2021-04-06 08:05:17 UTC
Regards
AW
MOD NOTE: originally posted in wrong board
Threads: 66
(2021-04-26, 04:46)Sareme Wrote: Hi
User - Sareme
Station - 2365
Regards
AW
Here is a case of looking at LIGHTNING MAPS.ORG instead of the Blitzortung site, where 2365 data is processed.
2365 supports and reports to 3 regions, and doing well:
2365 Pano Arodes Cyprus Europe 1 Running 2021-04-26 11:44 16477 9591 350 185 172 km 3765 km
2365 Pano Arodes Cyprus Asia 1 Running 2021-04-26 11:44 16493 9964 15 7 183 km 1236 km
2365 Pano Arodes Cyprus Africa 1 Running 2021-04-26 11:44 16491 8391 4 2 2032 km 4656 km
DO NOT rely on Lightningmaps.org for real-time, or correct information especially in such cases. It does NOT currently interface rapidly or correctly with much of the 'newer' database and algorithm processing on the Blitzortung servers.
