Strange goings on - started at 00:00 Oct 30 2022
Earlier this afternoon I discovered that my system ( 1890, system blue ) went offline at 00:00 on Oct 30 2022. Logging in to the box showed everything was working EXCEPT for GPS. Checking the GPS antenna, and trying another antenna, made no difference. The GPS light is off, and it shows as no GPS detected. Rebooting the box made no difference - GPS seems to be totally dead.
It was at this time that I discovered that according to the lightning maps, at least half of the detector sites in Australia seemed to have gone offline at the same time (00:00 on Oct 30, 2022).
This seems like a very unlikely coincidence!
The Blitzortung.org lightning map is also showing almost no lightning AT ALL in the Australian region, despite large numbers of severe thunderstorms currently active in several parts of the country - including a row of storms within 500km of my location!
What could be the cause of all this? How could more than half the detectors in the region go offline at the same time?  Huh
I managed to get my 2nd unit (2979) operational, and it seems to be working correctly. GPS has (finally) reached 95% availability - took well over 3 hours to do so....
Mick.
Thread closed... operator / developer discussion continues internal forum:
https://forum.blitzortung.org/showthread.php?tid=3648
-admin-
Stations: 1890, 2979
Hello
I have the same problem (Poland - 2070).
Looks like the problem is on PCB 19.4 and earlier.
PCB 19.5 is working fine.
Stations: 414, 2070
Since this night I also have a GPS problem. The log show every second that the year is not bewteen 2013 and 2031.
Did a reboot several time but does not work.
System Blue FW 9.2 / PCB 19/3 ID5/1
Station ID 1582
CHeers
Hardy
73 de Hartmut / DK5LH
Stations: 1582
Year not between 2013 and 2031 in the log.
Strange.
Stations: 1515
(2022-10-30, 08:22)mzseast Wrote: Earlier this afternoon I discovered that my system ( 1890, system blue ) went offline at 00:00 on Oct 30 2022. Logging in to the box showed everything was working EXCEPT for GPS. Checking the GPS antenna, and trying another antenna, made no difference. The GPS light is off, and it shows as no GPS detected. Rebooting the box made no difference - GPS seems to be totally dead.
Mick.
Mick,
The GPS for my station 2118 also went off at 00:00 on Oct 30, 2022. Location: Victoria, Australia.
Board Blue 19.4 @ firmware version 8.4.
Rob.
Stations: 2118
Same here since 1 hour. GPS fails. (Station located in Austria)
Hardware: PCB 19.4
Blue LED is blinking. About 2sek on, 2 sek off. No valid Timesignal.
Stations: 2116
The problem is in the GMM-G3 GPS module. Sends correct coordinates, altitude, current time.
Unfortunately, this data is contained in GPGGA and has an incorrect checksum (0000) than in the documentation for this module.
I suppose we will need a new firmware for the GMM-G3 or a new firmware for "Blitzortung.org Controller" which will not check that the checksum is correct.
Stations: 414, 2070
I have the same problem since some days.
The UK underwent a clock change lastnight and I wonder is the daylight savings stuff has messed up with some of users/servers. Meanwhile it might be helpfull if you state.
System?
PCB?
Firmware?
Ublox M8, whare ROM core are you running?
My Blue(19.5), FW9.2, with a ublox M8 running 3.01 ROM seems to be working fine for now.
Station 2828 - LM or BT
Stations: 2828
Just looking at the number on units out for the moment. Yikes, virtually anything blue older then 19.5 and its not working.
Not sure how hard it is to update the firmware,
.pdf   AirPrime_GMM_G3_XA11xx_and_XM11xx_Software_User_Guide_Rev4_0.pdf (Size: 717.02 KB / Downloads: 3)
This seems to be the current version,
https://source.sierrawireless.com/resour...Z3jRq.dpbs
Attached are the GMM-G3 and GMM-G3(B) firmware files.
.bin   AXN5.1.1_8526_3333_96.1151100.1.bin (Size: 626.81 KB / Downloads: 5)
.bin   AXN5.1.1_8525_3333_1152.1151100.1.bin (Size: 638.24 KB / Downloads: 6)
Stations: 2828
