Hello
I moved my station and on blitzortung everything looks right but not on lightningmaps, wrong info and location. Something i need to do?
The station in question is 2718
Threads: 11
Welcome on the forum. I have upped your status as participant so you have a lot more to read
Also do some searching on forum regarding LMO. is not actively maintained by Tobi (it is a side project and not official)
For up to date data and details you have to use
https://map.blitzortung.org/
Regarding location, yes it is fuzzy to preserve privacy of the users. It sets it in a circle a few kilometers wide around your spot and will often change a little inside that circle. But rest assured that the exact GPS data is used for strike calculations.
