2026-08-21, 21:23
My station (3290) is currently reporting to the Europe region even though I am in North America. Would that be the reason my used rate is low?
Region Assignment
2026-08-21, 21:23
2026-08-21, 22:59
(2026-08-21, 21:23)nolensb Wrote: My station (3290) is currently reporting to the Europe region even though I am in North America. Would that be the reason my used rate is low? That's likely because your station has retained it's original program slots from configuration and setup before shipping.... Egon needs to manually set the server slots for NA1 and NA2 for you. I'll send him a note, but you might follow up with an email through the board here... I'm also upgrading your forum credentials for access to the operator's boards Mike
2026-08-23, 00:56
(2026-08-21, 22:59)cutty Wrote:(2026-08-21, 21:23)nolensb Wrote: My station (3290) is currently reporting to the Europe region even though I am in North America. Would that be the reason my used rate is low? thank you!
2026-08-23, 17:17
You should be good to go, now...
3290 leeds United States / Alabama North America 2 Running 2026-08-23 17:14 3290 leeds United States / Alabama North America 1 Running 2026-08-23 17:14
2 hours ago
Thanks for sharing this, I had a similar issue with my station configuration when setting it up. Glad to see cutty got it sorted out quickly for you.
« Next Oldest | Next Newest »
