1 hour ago
Conquest gives you a calmer way to build a Diamond Dynasty roster without living in ranked games. You choose the route, pick the matchups, and decide when to play or simulate, while rewards can still support your MLB The Show 26 Stubs goals and collection plans.
What Makes Conquest Worth Your Time
It is a territory mode built around choice. You are not locked into one route or one lineup.
Need player XP, packs, or a program mission? Set the map up around that target, then move at your own pace.
1 Shark Map for Repeat Pack Runs
This is the map for players who want to keep opening packs after a clear. Its value comes from replay value, not just a one-time reward screen.
Look out for these rewards.
• Hidden pack spots spread across the map.
• Completion rewards with premium pack options.
• A route you can run again when you want more pulls.
Shark works well when you have a reliable routine. Clear the useful spaces, take the strongholds, then start another run when you are ready.
2 Lightning Map for Fresh Program Progress
Lightning is a good first clear when your current programs still need games, XP, or player missions. It has a wider reward mix than a simple pack-only map.
What you can work toward.
• Headliners-style pack rewards.
• Deluxe and Premier pack opportunities.
• Program-related progress and XP.
Its strongest stretch is the first completion. Bring players tied to active missions, and each game can do more than one job.
3 Subway Map for a Wide Reward Spread
Subway fits players who do not want to chase one pack type. There is a solid mix of hidden finds and completion prizes across the board.
Key stops on the route.
• Several hidden The Show Packs.
• Hidden Headliners and Deluxe packs.
• A Vault Choice Pack and a Live Series reward at completion.
Spend a minute checking the map before moving fans. Missing a hidden space can make the run feel much less worthwhile.
4 Planet and Summer Maps for Extra Inventory
These maps make sense after the higher-value targets are finished. Planet leans toward a larger count of standard packs, while Summer adds more variety.
Reasons to clear them.
• Planet has multiple Deluxe and Headliners rewards.
• Planet also hides ten The Show Packs.
• Summer adds more pack locations for a later run.
They are useful filler when you want offline innings. Keep the route tight and do not wander into games that do not help an objective.
Which Conquest Map Should You Choose
Pick Shark for repeat runs, Lightning for active programs, Subway for variety, and Planet for more standard packs. When your roster needs a quicker lift, MLB 26 Stubs can help you turn those pack pulls into a more complete squad.
