Efficiency
Thanks. Kerri
Stations: 1306
No answer ?
Thomas
Stations: 1006, 1305
That's not correct Wink
or better :
Is this correct ?
Thomas
Stations: 970
(2015-06-05, 14:32)Knickohr Wrote: That's not correct Wink
Oops, sorry. Undecided  You are right!
Hi Folks,
Then we have:
Much fun,
Egon
Thats very interesting Egon !
http://forum.blitzortung.org/showthread....28#pid9628
Thomas
Then we have:
Much fun,
Egon
Hi Egon,
I get the general idea of the new computation (quite hard for someone one who sucs at maths...)  But i am trying to figure out what the Y in "min (x,y) = minimum of x and y" stands for. I thought i'd just ask Blush .
Gerhard
Stations: 711, 1351
(2015-06-14, 21:35)Egon Wrote: This is the old effectivity value multiplied by the factor min (Strikes / Signals(s), Signals(s) / Strikes) to consider also the strikes/signals relation (and to punish the stations that send a lot of trash  Wink ).
Hi Egon.
I think it´s a good idea to punish station with bad effiency, but i do not understand, what this factor is. If i look in the stations list i see my station has sometimes not so good efficiency, although there are some signals and many lightning strikes.
I have (mostly around the weekend) short periods with a lot of noise, often only once a day. Is that the reason for worse efficiency? Is the time period of your factor 1 day or longer?
Knolau
Stations: 920, 2270
