what is the best setup for BO??
well.. x fingers...
was tired of pulling my hair in frustration, and went over the AMP with the iron... and seems like that helped Smile
Ill see if it does the usual trick with working ok first, and then give me the usual Noise...
Stations: 1145
Whowww !
Much better signals Wink But very high gains for amp1. Is this normal for an coax-loop ?
One point left. Disable channel C on amp 1 (yellow).
Thomas
Stations: 1006, 1305
Thank you for pointing me in the correct direction Thomas. I have to be honest enought to tell you my coax cable is old and bad. . Bought first 200m of high ql cable in a hurry . And grabbedvone with alu shielding Sad and had about 100m of similar.
So i found some really old coax that probably worked best last decade Smile so it is on the todo list. Had just my faulty soldering to figure out. . So now i can focus on a smaller house project before i make new antenna Smile
Stations: 1145
