System BLUE / capability to handle external RF fields
(2015-07-04, 19:32)Steph Wrote: I had no problems with 100W in 20m distance at 14MHz. The bigger problem was interference from the switching power supply of the transceiver.
Good point here... I have heard similar comments from local ham radio operators, who run also BO equipment. Althoug SMPS would not be main topic of this thread - it needs to be considered as potential interference source.
I have also planned to modify HP server 12V power supply for amateur radio use, and it also used SMPS principle Undecided . If there is interference, remains to be confirmed...
