Adding AS3935 board - Printable Version +- Blitzortung.org Forum (https://forum.blitzortung.org) +-- Forum: Public Forums (https://forum.blitzortung.org/forumdisplay.php?fid=29) +--- Forum: Hardware, Software, Lightning Physics (https://forum.blitzortung.org/forumdisplay.php?fid=30) +--- Thread: Adding AS3935 board (/showthread.php?tid=1022) |
AS3935 - jrm30655 - 2015-01-07 Has anyone run one of these chips in a controller board? Adding AS3935 board - jrm30655 - 2015-01-10 I recently bought a AS3935 board like this: https://www.tindie.com/products/TAUTIC/as3935-lightning-sensor-board/ Can anyone advise on how to add this into the system? RE: Adding AS3935 board - cutty - 2015-01-10 (2015-01-10, 16:03)jrm30655 Wrote: I recently bought a AS3935 board like this: https://www.tindie.com/products/TAUTIC/as3935-lightning-sensor-board/There is numerous discussion,. Search forum here and at WxForum.net. You may have much better results searching and posting inside the "internal" forums for station operators. What is your station number? RE: Adding AS3935 board - jrm30655 - 2015-01-10 (2015-01-10, 17:28)Cutty Wrote:(2015-01-10, 16:03)jrm30655 Wrote: I recently bought a AS3935 board like this: https://www.tindie.com/products/TAUTIC/as3935-lightning-sensor-board/There is numerous discussion,. Search forum here and at WxForum.net. You may have much better results searching and posting inside the "internal" forums for station operators. What is your station number? RE: Adding AS3935 board - cutty - 2015-01-10 (2015-01-10, 22:02)jrm30655 Wrote:1218(2015-01-10, 17:28)Cutty Wrote:(2015-01-10, 16:03)jrm30655 Wrote: I recently bought a AS3935 board like this: https://www.tindie.com/products/TAUTIC/as3935-lightning-sensor-board/There is numerous discussion,. Search forum here and at WxForum.net. You may have much better results searching and posting inside the "internal" forums for station operators. What is your station number? Yes, I thought you were in Mexico... Although there is info here on BO forum, I'd suggest going to http://www.wxforum.net/ and search posts for "AS3935" There are many hints, experiences and troubleshooting tips there.... Mike |
