Station projekt showing more then once! - Printable Version +- Blitzortung.org Forum (https://forum.blitzortung.org) +-- Forum: Public Forums (https://forum.blitzortung.org/forumdisplay.php?fid=29) +--- Forum: General Discussion (https://forum.blitzortung.org/forumdisplay.php?fid=31) +--- Thread: Station projekt showing more then once! (/showthread.php?tid=3699) |
Station projekt showing more then once! - Ldarax - 2023-04-14 All station show up 3 times with different numbers when i ceck on stations by country! How come? RE: Station projekt showing more then once! - mendip_defender - 2023-04-15 Its a quirk of the system. My station detects strikes outside my general area, this month the furthest has been 10.5 Mm (mega-metres) so therefore I apear on stats for other areas. Due to the way the severs work that measn my station and many others appear multiple times. I think they were looking at fixiing or improving it but this is thier hobby and not some full time job. I wouldn't worry about it. RE: Station projekt showing more then once! - cutty - 2023-04-15 (2023-04-14, 20:34)Ldarax Wrote: All station show up 3 times with different numbers when i ceck on stations by country!That's because your signals are counting to three regional areas on the Europe Region, and you get additional listings with strokes assigned to each area: 2632 Ängafallet System Blue Sweden Europe 1 I believe “1” is the 'Global' Region ... ALL Global stations' signals resolved to 'Europe' 2632 Ängafallet System Blue Sweden Europe 2 2632 Ängafallet System Blue Sweden Europe 3 are some specific geographical station grouping 'regions' EXAMPLE the North America region currently has 2 : something like, (unless it's changed recently): North America 1 (NA Global) — Updates @ 1-5 min — All GLOBAL stations localizing Atlantic, Pacific, Americas. North America 2 (NA Local) — Updates @ 1 min — NORTH AMERICA stations ONLY localized. These computing server assignments are under development and may change ![]() |
