GPS hosed - Printable Version +- Blitzortung.org Forum (https://forum.blitzortung.org) +-- Forum: Public Forums (https://forum.blitzortung.org/forumdisplay.php?fid=29) +--- Forum: Hardware, Software, Lightning Physics (https://forum.blitzortung.org/forumdisplay.php?fid=30) +--- Thread: GPS hosed (/showthread.php?tid=3737) |
GPS hosed - hpfeil - 2023-08-04 Station 2707 status: Bad GPS. I replaced the GPS antenna. There was overhead lightning, nearby strikes. The GPS section of the station web interface shows no 1PPS, no satellites. Before the storm, there were 5-6 satellites on the polar graph, position data, everything was working. If I need a new board, I will connect the grounding jack to earth ground. |
