Linking accounts - Printable Version +- Blitzortung.org Forum (https://forum.blitzortung.org) +-- Forum: Public Forums (https://forum.blitzortung.org/forumdisplay.php?fid=29) +--- Forum: Website, Maps and Applications (https://forum.blitzortung.org/forumdisplay.php?fid=24) +--- Thread: Linking accounts (/showthread.php?tid=3947) |
Linking accounts - icpass - 2024-09-22 Hi I have just setup my mini blue ,I was wondering how to link my blitztorung account with the forum.some info on the forum is blocked .also how do I link it with lightning.org,when I first setup it let me logged in now it won’t my I’d is 3101 RE: Linking accounts - gerbold - 2024-09-23 Unfortunatelly I can't answer your question. May I assume your station id is 3101 but your user id is 2407? RE: Linking accounts - icpass - 2024-09-23 yes thats correct RE: Linking accounts - cutty - 2024-09-23 (2024-09-23, 11:55)icpass Wrote: yes thats correct 3101 is your Blitzortung Station ID number, Bath, UK...NOT your user number. see your performance HERE and 3101 is registered into all three Europe regions, so you'll see three listings on 'Station List' page. Your 3101 station is NOT available on the adjunct website Lightningmaps.org. Lightningmaps is administered by Tobi, is adjunct to Blitzortung, and is on Tobi's list to be restructured later, hopefully, currently does NOT process all the latest changes and updates of the main Blitzortung computations and databases. The forum, and Lightningmaps.org, are separate from the 'official' Blitzortung website, and may in fact operate under different credentials. (Like Me, and many others with older stations, must use separate credentials) If so, your forum and/or Lightningmaps.org USED ID and PASSWORD may not work on the MAIN Operator's section on BLITZORTUNG, and vice versa, or other weird 'vice versas'. In Fact, in the future, perhaps even now, Lightningmaps MAY require Blitzortung Operator credentials rather than forum credentials, once the adjunct is fully configured to match main Blitzortung... just a suspicion. Now that I've thoroughly confused you and everyone, including me...: Rely on any statistics etc from the 'official' Blitzortung.org website, for the foreseeable future. I've updated ICPASS on the forum to 'Participant' status, so you should now have the additional access. (I might suggest you go back to your Blitzortung operator's page and correctly configure the antennas to match your actual install). Clear as mud, right???
RE: Linking accounts - icpass - 2024-09-25 Cutty Clear as mud except for the last bit about configuring antenna,I’m not sure what you mean. Ian RE: Linking accounts - cutty - 2024-09-25 (2024-09-25, 15:06)icpass Wrote: Cutty example RE: Linking accounts - icpass - 2024-09-25 Is it more beneficial for me to be in manual mode rather than auto RE: Linking accounts - mwaters - 2024-09-25 (2024-09-25, 19:14)icpass Wrote: Is it more beneficial for me to be in manual mode rather than auto Usually! Manual mode with Adapt to Noise on. :-) RE: Linking accounts - ga3lig - 2025-07-29 Hello, I'm using this thread, as the title is still accurate :) I'm user ga3lig user: 2445 detector: 3180 With the same username in Blitzortung website and forum. The automatic login in forum from blitzortung didn't work, so I created manually my forum account. Unfortunately, the automatic linking between both account didn't work either. I'm looking for tips to increase the accuracy of detections for my station, can you upgrade my forum account to be able to access to participant threads ? Regards, RE: Linking accounts - Eric.Wouters - 2025-07-29 (2025-07-29, 07:22)ga3lig Wrote: Hello, there you go, welcome to the club and enjoy the reading/learning |
