DIY Lightning Detection System Using Microcontrollers – Beginner Setup Guide - Printable Version
+--- Forum: Hardware, Software, Lightning Physics (https://forum.blitzortung.org/forumdisplay.php?fid=30)
+--- Thread: DIY Lightning Detection System Using Microcontrollers – Beginner Setup Guide (/showthread.php?tid=4211)
DIY Lightning Detection System Using Microcontrollers – Beginner Setup Guide - Danieldsouza - 2026-04-01
Hi everyone,
I’ve been exploring how lightning detection systems work and wanted to share a simple DIY approach for beginners who are interested in experimenting with electromagnetic detection and real-time monitoring.
How Lightning Detection Works (Basic Idea)
Lightning strikes generate electromagnetic pulses (EMP) across a wide frequency range. These signals can be captured using:
  • RF antennas
  • Signal amplification circuits
  • Microcontrollers for processing
By analyzing the signal strength and timing, it’s possible to detect and even estimate the distance of lightning activity.
Basic Components You Can Use
For a simple setup, you can start with:
  • A microcontroller (like Arduino or Raspberry Pi)
  • RF receiver module or lightning sensor module
  • Antenna (simple wire antenna works for testing)
  • Optional: OLED/LCD display for output
  • Power supply + basic passive components
Simple Workflow
  1. Capture electromagnetic signals using the antenna
  2. Feed the signal into an RF module or detection circuit
  3. Process the signal using a microcontroller
  4. Display or log the detected activity
Possible Enhancements
Once the basic system works, you can expand it by:
  • Logging data to a cloud platform
  • Adding GPS for location-based tracking
  • Integrating with weather APIs
  • Building a network of detectors for triangulation
Challenges I Noticed
  • Filtering noise from real lightning signals
  • Improving detection range and accuracy
  • Handling interference from nearby electronics
Would love to hear from others who have tried building similar systems or experimented with RF-based detection. Any tips on improving signal accuracy or filtering noise would be really helpful!
Discussion
Has anyone here built a custom lightning detector from scratch?
What frequency ranges worked best for you?
Any recommended modules or approaches for better accuracy?
Looking forward to your insights!
