Throughole components - partlist (Blue Basic 22.2b/c 23.1) - Printable Version +- Blitzortung.org Forum (https://forum.blitzortung.org) +-- Forum: Public Forums (https://forum.blitzortung.org/forumdisplay.php?fid=29) +--- Forum: Hardware, Software, Lightning Physics (https://forum.blitzortung.org/forumdisplay.php?fid=30) +--- Thread: Throughole components - partlist (Blue Basic 22.2b/c 23.1) (/showthread.php?tid=4243) |
Throughole components - partlist (Blue Basic 22.2b/c 23.1) - dd1sb - 2026-06-27 Hi guys, with my last PCB order i decided to add the System Blue Basic 22.2b with Piggyback 22.2c and Preamp 23.1. Adding the official partlist from the directory to my last Digikey order worked like a charm. Except one thing: the throughole components are not in there All of them are more or less easy to identify on the pictures, but i got one simple problem.Which quarz oscillators 8 / 25MHz do i have to use - the CL (or Belastungskapazität) on the board is 10pF, everything else results in a slightly lower or higher frequency. What about the capacity of the tracks etc., do i have to pay attention at them? That would lead to a quarz with a CL > 10pF As the system should be used for participation later on, i'd like to have all values as close as possible to the "detector kit". I'd also buy a "throughole component kit" (as seen on the picture on limaps org hardware ) if that is the easier way ![]() Cheers, 73 & 77 de Stefan, DD1SB |
