Threads: 3
Thanks. Kerri
Threads: 14
No answer ?
Thomas
Stations: 1006, 1305
Threads: 78
2015-06-05, 14:02
(This post was last modified: 2015-06-05, 14:41 by Tobi.)
Threads: 14
2015-06-05, 14:32
(This post was last modified: 2015-06-05, 14:36 by Knickohr.)
That's not correct
or better :
Is this correct ?
Thomas
Threads: 6
2015-06-05, 14:33
(This post was last modified: 2015-06-05, 14:36 by andyweather.)
Threads: 78
(2015-06-05, 14:32)Knickohr Wrote: That's not correct
Oops, sorry.  You are right!
Threads: 55
2015-06-14, 21:35
(This post was last modified: 2015-06-14, 22:06 by Egon.)
Hi Folks,
Hits (x,s) = number of strikes in a range of x km to station s at that station s was involved
Then we have:
Effectivity_5000 = Hits (s,5000) / Strikes(s,5000) * min (Strikes / Signals (s), Signals (s) / Strikes)
This is the old effectivity value multiplied by the factor min (Strikes / Signals(s), Signals(s) / Strikes) to consider also the strikes/signals relation (and to punish the stations that send a lot of trash  ).
Much fun,
Egon
Threads: 14
2015-06-15, 17:07
(This post was last modified: 2015-06-15, 17:11 by Knickohr.)
Thats very interesting Egon !
https://forum.blitzortung.org/showthread....28#pid9628
Thomas
Threads: 15
Then we have:
Much fun,
Egon Hi Egon,
I get the general idea of the new computation (quite hard for someone one who sucs at maths...) But i am trying to figure out what the Y in "min (x,y) = minimum of x and y" stands for. I thought i'd just ask  .
Gerhard
Threads: 1
(2015-06-14, 21:35)Egon Wrote: This is the old effectivity value multiplied by the factor min (Strikes / Signals(s), Signals(s) / Strikes) to consider also the strikes/signals relation (and to punish the stations that send a lot of trash ).
Hi Egon.
I think it´s a good idea to punish station with bad effiency, but i do not understand, what this factor is. If i look in the stations list i see my station has sometimes not so good efficiency, although there are some signals and many lightning strikes.
I have (mostly around the weekend) short periods with a lot of noise, often only once a day. Is that the reason for worse efficiency? Is the time period of your factor 1 day or longer?
Knolau
Threads: 55
2015-06-22, 21:11
(This post was last modified: 2015-06-22, 21:12 by Egon.)
Much fun,
Egon
Threads: 14
2015-06-25, 14:57
(This post was last modified: 2015-06-26, 17:09 by Knickohr.)
Thomas
Threads: 23
2015-06-25, 15:48
(This post was last modified: 2015-06-25, 15:52 by Steph.)
(2015-06-25, 14:57)Knickohr Wrote: I played a little bit with the "new" efficiency So did I:
Example:
(Database is still building)
Usage:
Code: http://crna.zapto.org/plotblitz/efficiency.php?id=Station-ID
Optional Parameters:
Threads: 14
2015-06-27, 14:22
(This post was last modified: 2015-06-29, 17:57 by Knickohr.)
Thomas
Threads: 15
Much fun,
Egon
I am puzzled  I'm trying to get optimal results, and I use the participants page for checking the results. For what I understand the signals-rate is used in the calculation. So how can it be that one station has about double the signals, and less strikes be higher in the ranking? This would mean that sending more signals, and record less strikes is better...
Gerhard
Threads: 23
There is no optimal setting for all eventualities. I think if you're in the two-figure-number efficiency, it's all good
Threads: 1
(2015-07-19, 14:37)Gerhard.Wittevee Wrote: Quote:So how can it be that one station has about double the signals, and less strikes be higher in the ranking?
Good question  I regularly take a look at this tables to control the work of my station and to compare it with the stations in my neighborhood. BO Neighbors
But very often i don´t understand what I see. There shouldn´t be so big differences.
The explanation of Egon does not convince me. I think there is something wrong with the new calculation. I know, that I should not take it seriously, but I am always surprised about the results.
Knolau
Threads: 15
Quote:I know, that I should not take it seriously
I agree that we should not have a competition. That does not help the network as a whole. But these values are the only way to compare, and to improve our stations. Those improvements are in the interest of the network as a whole. That is why, as Egon wrote (with a  ) "To punish stations who send a lot of trash", a calculation taking the number of signals into account is a good idea. But comparing just got harder. With the old calculation I could change gain- or threshold and see the station creeping up the list, or going down the list. The new values change constantly, so comparing even your own settings is virtually impossible.
Gerhard
Threads: 14
Thomas
Threads: 15
Thomas
Thanks Thomas,
Gerhard
