System RED with off the shelf Atmegas
Hi
Last night I finally got around assembling the System RED that has been sitting on my shelf for a very long time now. (Really sorry about that. Reason: children)
The Atmega8's are off the shelf (not kit ones) and I'm guessing that they have to be programmed but I cannot find any information about this in the documentation or in the forum?
You'll the firmware at http://fr.blitzortung.org/Compendium/Firmware/ Wink
Don't forget to read Red_PCB_12_PCB_13_ATMEGA_info.txt.
Thank you.
I see that the latest fw there is 1.7, but trough a little googling yesterday I found 1.8.
I was lacking the fuse info, very helpful!
1.8 is for system BLUE.
For system RED use one of those:
Red_PCB_12_PCB_13_ATMEGA-48_1.6.hex
Red_PCB_12_PCB_13_ATMEGA-48_1.7.hex
Red_PCB_12_PCB_13_ATMEGA-8_1.6.hex
Red_PCB_12_PCB_13_ATMEGA-8_1.7.hex
Depending if you have Atmega48 or Atmega8.
V1.7 also handles E-Field amplifier.
Got both amps flashed with 1.7 and the correct fuse settings, works perfectly now!
Ready to go online, just waiting for an account.
Thanks again.
Users browsing this thread: 11 Guest(s)
