System Blue order status (10.3.2020)
#21
I would also be interested.
#22
I've had a look at the cover your area to register, however my country isn't in the list!
Jersey - https://en.wikipedia.org/wiki/Jersey
Country code
Alpha2 : JE
Alpha3 : JEY
Regards
Mack
#23
I want to order Blue model
Wysłane z iPhone za pomocą Tapatalk
#24
I've just registered on Check My Area and I am currently ranked "9991 of 9993".
Am I correctly registered as an interest for a System Blue, and can you tell me how much I need to save in order to buy the kit when I get the invitation to order please?
I am a trained Electronics Repair Engineer with over 40 years experience and I have no problems with surface–mount assembly/repair and rework!
Do enclosures come ready cut/machined and labelled?
My location is Walsall, West Midlands, United Kingdom
Chris Williams
#25
(2023-07-09, 17:59)Chris56000 Wrote: I've just registered on Check My Area and I am currently ranked "9991 of 9993".
Chris Williams
It may take some time are there are some issues getting some of the parts for the boards and the cost of producing them has shot up as well.
For an idea of the kit see how I setup mine.
https://blog.jackstringer.co.uk/misc/202...lightning/
Station 2828 - LM or BT
Stations: 2828
#26
(2022-02-27, 18:43)Egon Wrote: Dear all,
here are the layout files for system red:
https://www.blitzortung.org/Compendium/L...SystemRed/
There are currently extreme bottlenecks in procuring the components for the blue system. We will therefore not be able to offer circuit boards for System Blue again until the third quarter of this year at the earliest.
Hello, I want to do System red with a friend.
The provided files do not have complete paths. Can you share the finished Eagle files? Will you then add my system red to the map?
#27
THIS POST  DELETED AT TONU'S REQUEST
12/02/2023
#28
THIS POST DELETED BY CUTTY 12/02/2023
#29
Very good, Mike and Tõnu! :-)
Are these boards going to be available mostly populated, as Egon's boards were?
This Post has been redacted here, and original is moved to
https://forum.blitzortung.org/forumdisplay.php?fid=47
_______________________________________________
I been populating everything I can, so I can actually check if board works or not.
Because of massive amount of tiny changes every new revision of board is ordered in 2pcs. Then it takes time to receive them, test them, then unknown amount of four letter words I order new batch of 2pcs, test them etc. Not willing to build high expectations, so I keep mute about progress. All I want to say, I work on all this. Not only boards but on anything I can do about project. Everything takes some time and money. Been also looking on ways to build cheaper antennas, casing which would fit my usual needs etc. Armed with experience running dozens of devices for years I hope to build newer, slightly improved version for public use in future.
#31
 IT OCCURRED TO ME:
... these last few posts, and the encouraging forward movement of the 'network' and hardware, are moving into a stage of 'redevelopment', and the 'next generation' might require a more 'private' discussion area...
so... I've moved these last few posts into '2023 Developing' restricted internally.... if you're currently authorized (access restricted) you can access it at
We might progress better in 'redefining' new hardware, etc, here.?
#32
This Post has been moved to https://forum.blitzortung.org/forumdisplay.php?fid=47
THIS POST REMOVED BY CUTTY 12/02/2023
#34
SO....
To redirect back to this THREAD'S original topic, ///
ANY posts or queries NOT related to 'Order Status' from here on will either be moved to a more applicable thread, to the new internal restricted  '2023 developing' thread, if applicable, or just deleted...
  How to order system blue-basic? Kellogs 3 56,592 2025-04-20, 00:09
Last Post: DrFX
  Does the System Blue Basic take the same Firmware as System Blue? DrFX 3 51,850 2025-04-19, 23:25
Last Post: DrFX
  Can I order? larryf 1 40,703 2024-09-07, 20:55
Last Post: gerbold
Lightbulb System RED available - Nov 2020 - SOLD africaone 2 26,651 2020-11-27, 21:15
Last Post: africaone
  Station 1406 offline 2,9-24,9,2020 puuhailia71 0 16,863 2020-09-01, 18:00
Last Post: puuhailia71
