Efficiency
Thanks. Kerri
Stations: 1306
No answer ?
Thomas
Stations: 1006, 1305
That's not correct Wink
or better :
Is this correct ?
Thomas
Stations: 970
(2015-06-05, 14:32)Knickohr Wrote: That's not correct Wink
Oops, sorry. Undecided  You are right!
Hi Folks,
Then we have:
Much fun,
Egon
Thats very interesting Egon !
https://forum.blitzortung.org/showthread....28#pid9628
Thomas
Then we have:
Much fun,
Egon
Hi Egon,
I get the general idea of the new computation (quite hard for someone one who sucs at maths...)  But i am trying to figure out what the Y in "min (x,y) = minimum of x and y" stands for. I thought i'd just ask Blush .
Gerhard
Stations: 711, 1351
(2015-06-14, 21:35)Egon Wrote: This is the old effectivity value multiplied by the factor min (Strikes / Signals(s), Signals(s) / Strikes) to consider also the strikes/signals relation (and to punish the stations that send a lot of trash  Wink ).
Hi Egon.
I think it´s a good idea to punish station with bad effiency, but i do not understand, what this factor is. If i look in the stations list i see my station has sometimes not so good efficiency, although there are some signals and many lightning strikes.
I have (mostly around the weekend) short periods with a lot of noise, often only once a day. Is that the reason for worse efficiency? Is the time period of your factor 1 day or longer?
Knolau
Stations: 920, 2270
Much fun,
Egon
[Image: efficiency_l.png]
Thomas
(2015-06-25, 14:57)Knickohr Wrote: I played a little bit with the "new" efficiency
So did I:
Example:
(Database is still building)
Usage:
Code:
http://crna.zapto.org/plotblitz/efficiency.php?id=Station-ID
Optional Parameters:
Stations: 233
[Image: efficiency_m.png]
[Image: efficiency_s.png]
[Image: efficiency_g.png]
Thomas
Much fun,
Egon
I am puzzled Sad I'm trying to get optimal results, and I use the participants page for checking the results. For what I understand the signals-rate is used in the calculation. So how can it be that one station has about double the signals, and less strikes be higher in the ranking? This would mean that sending more signals, and record less strikes is better...
Gerhard
Stations: 711, 1351
There is no optimal setting for all eventualities. I think if you're in the two-figure-number efficiency, it's all good Wink
Stations: 233
(2015-07-19, 14:37)Gerhard.Wittevee Wrote:
Quote:So how can it be that one station has about double the signals, and less strikes be higher in the ranking?
 Good question Smile I regularly take a look at this tables to control the work of my station and to compare it with the stations in my neighborhood. BO Neighbors
But very often i don´t understand  what I see. There shouldn´t be so big differences.
The explanation of Egon does not convince me. I think there is something wrong with the new calculation.  I know, that I should not take it seriously, but I am always surprised about the results.
Knolau
Stations: 920, 2270
Quote:I know, that I should not take it seriously
I agree that we should not have a competition. That does not help the network as a whole. But these values are the only way to compare, and to improve our stations. Those improvements are in the interest of the network as a whole. That is why, as Egon wrote (with a  Wink) "To punish stations who send a lot of trash",  a calculation taking the number of signals into account is a good idea. But comparing just got harder. With the old calculation I could change gain- or threshold and see the station creeping up the list, or going down the list. The new values change constantly, so comparing even your own settings is virtually impossible.
Gerhard
Stations: 711, 1351
Thomas
Thomas
Thanks Thomas,
Gerhard
Stations: 711, 1351
Users browsing this thread: 18 Guest(s)
