Red system 7.4 to 8.1 network no good !
I have the RED system with version 7.4 which works fine. I wanted to move to version 8.1 but after 20 minutes there is no network connection and asked me to check the network cable. I tried version 8.0 and 8.1, the same finding, network problem !!!
Have you an idea about this failure.
Thank you and read you
JAK
I handed version 7.4 and no problem!
Stations: 1417
I don't know why this happened. Can you please update to 8.1 again and stay there for a while? Some debug output can help too. Can you provide some information about your network (i.e. DHCP, basic network scheme etc.).
(2016-09-27, 10:17)Tobi Wrote: I don't know why this happened. Can you please update to 8.1 again and stay there for a while? Some debug output can help too. Can you provide some information about your network (i.e. DHCP, basic network scheme etc.).
Many many thanks
My network : 192.168.1...
Network system Red is 192.168.1.40 ( same red version 7.4 )
DHCP : on
No probleme with 7.4 version but with 8.0 and 8.1 its ok for 20 minutes and after network down !!!
To day at 12:00 UTC i put 8.1 version and wait .
See you at the next , many thanks Tobi
Stations: 1417
Many many thanks
DHCP : on
After 18 minutes , all ok , look the photo.
tks
Stations: 1417
There seems to be a memory allocation problem. It's not directly related to the network connection. I will investigate.
PS: Please leave the station running this way! Thanks!
(2016-09-27, 12:36)Tobi Wrote: There seems to be a memory allocation problem. It's not directly related to the network connection. I will investigate.
OK Tobi, thanks
my station works since 27/09/16 at 12:40 utc after reset ( black button ).
see you
JAK
Stations: 1417
OK Tobi, thanks
see you
JAK
after ten minutes, on the display: Check network cable connection... networks down...
Stations: 1417
OK Tobi, thanks
see you
JAK
Tobi, its OK now, after 30 minutes with network down without touching anything, its OK !!!
Many thanks
best regards
Stations: 1417
OK Tobi, thanks
see you
JAK
Many thanks
best regards
Bonjour et merci Tobi ça fonctionne super bien.
All OK many thanks.
Stations: 1417
The problem occurs only when the station is registered for more than one region in combination with compression. It will be fixed in the next firmware.
(2016-09-28, 06:55)Tobi Wrote: The problem occurs only when the station is registered for more than one region in combination with compression. It will be fixed in the next firmware.
Helle Tobi,
I just installed version 8.2 and it works great. Tobi thank you very much.
Regards
Stations: 1417
  Network not working on System blue Ldarax 0 4,998 2020-06-05, 15:33
Last Post: Ldarax
