2015-11-11, 19:38
(2015-11-11, 16:10)John.Sacrey Wrote: System Blue is currently under development. Its release status is unknown. The current Red system does not require a computer connection, only a network/internet connection. It has its own built-in web server and can be accessed with a browser.
Once System Blue has been tested to the developers' satisfaction, they will commence a production run of the boards/components, etc. The price on a Red system was around $200 +/- based on the currency conversion rate. I know System Red is out of production, and I don't think there any left. That is a question for Egon or Tobi to answer.
I do not know what "versions" that System Blue will come in. System Red was a kit of around 200+ parts that you soldered onto the PC boards.
The most recent guide for System Red can be found under the "Cover Your Area" tab up above. It is a .pdf download with the description of how the TOA/TOGA systems works and the assembly of System Red.
Blitzortung TOA/TOGA data can not be used for commercial purposes.
Hope this helps,
John Sacrey
OK so I got blue system will have its own hardware its not just a software/firmware change.
I should wait for its release.
the PDF has all the parts I would need but I would have to build the CAD/GERBER files for the PCB myself since they aren't shared
I cannot sell the data.
this sound about right?
