Cables needed for System Blue
To router -  RJ45
To H-Field - RJ45 shielded
   (not in the same cable channel as RJ45 to router - if necessary, more than 10cm space)
To E-Field - Good quality 75 Ohm coax double shielded
To GPS antenna
   (normal lengh about 3m - loss to high if over 5m with standard cable. It can be longer, but frequency is 1575 MHz, and the gain of the antenna is about 20-26dB and it is necessary to know cable specifications for that frequency)
To USB power , about 350mA
To Ground?
   (I recommend an independent ground for Controller with thick grounding cable)
   (In theory it is unnecessary, but no one knows the electrical levels in the connected cables)
Cables needed for System Blue - by MDMD - 2016-04-23, 13:06
RE: Cables needed for System Blue - by RichoAnd - 2016-04-23, 15:49
RE: Cables needed for System Blue - by MDMD - 2016-04-24, 11:47
RE: Cables needed for System Blue - by cutty - 2016-04-24, 13:04
  Does the System Blue Basic take the same Firmware as System Blue? DrFX 3 52,219 2025-04-19, 23:25
Last Post: DrFX
  System needed KE7WWT 0 15,428 2016-09-11, 11:57
Last Post: KE7WWT
