General questions for a new system
If you can use LW radio. You can also use the VLF antenna (Loop or Ferrite)
E-Field antenna must sit outside - You can use either H-Field or E-Field or both
As the cables to the antennas often sit near other cables that interfere, we I set a limit of 30m - If the cable is free for nearby cables, it can easily be 40-50m
The resistance of a wire in 50m cable is 4.2 ohms, so it makes no noticeable loss.
/Richo
RE: General questions for a new system - by RichoAnd - 2016-06-06, 13:06
  New system, noob questions Junebug 4 40,143 2016-07-18, 18:33
Last Post: DelandeC
  More system blue antenna questions Adrian Hudson 2 31,300 2016-05-19, 13:49
Last Post: Adrian Hudson
