Fault LED indicates fault
(2016-09-15, 16:33)elythomaslumber Wrote:
(2016-09-15, 09:41)Bergkvar Wrote:
(2016-09-14, 11:00)elythomaslumber Wrote:
the other LED's? they ar ok
no interference.
Good luck!
Thank i find it now its working fine now
Stations: 148, 1598, 1601
Fault LED indicates fault - by j82 - 2016-06-30, 08:55
Fault LED indicates fault - by DelandeC - 2016-06-30, 09:45
RE: Fault LED indicates fault - by j82 - 2016-07-01, 11:20
RE: Fault LED indicates fault - by LennartJ - 2016-09-13, 09:29
RE: Fault LED indicates fault - by Bergkvar - 2016-09-15, 09:41
RE: Fault LED indicates fault - by LennartJ - 2016-09-16, 12:01
RE: Fault LED indicates fault - by Tobi - 2016-09-20, 08:40
  Fault mode after big electrostatic discharges. ant01n3 1 13,950 2024-01-30, 22:55
Last Post: dupreezd
  fault led at first boot uvash 3 26,983 2021-11-18, 10:37
Last Post: aloha20
  How to get alerts of fault or missing GPS jchonig 2 21,268 2020-12-30, 18:23
  Flashing networks led Alanpenwith 1 22,255 2018-09-14, 08:44
Last Post: Polyphemus
  LED placement question SteveQlQ 6 51,475 2018-02-04, 16:14
Last Post: cernese
