System Blue Not Working
No, it does not sound normal. I do not have an answer, but I have some more questions.
Do you have a copy of the schematic diagram? It is available on this forum from Project Area / Compendium, and will help you out lots!
Can you ping your device, does it show up on a port scan, or on the configuration page of your router? Maybe it is alive for a few seconds, then dies.
What is the rating of your USB power supply?
Can you measure the supply voltages on the board from the header connector? If yes, what are they?
The 5V line  on my system is around 4.6-4.7V. The 3.3V line is between 3.25V and 3.31V.
Your GPS will probably not work well in the basement, although mine was fine indoors.
Related to this question, roughly where in the world are you, some old versions of the firmware had problems in Australia and Japan.
I might not be able to help you out with these answers, but it might get other minds working!
Stations: 1515
System Blue Not Working - by tferoli - 2016-09-26, 23:53
RE: System Blue Not Working - by DnH2016 - 2016-09-27, 00:14
RE: System Blue Not Working - by piepants - 2016-09-27, 02:16
RE: System Blue Not Working - by tferoli - 2016-09-27, 02:24
RE: System Blue Not Working - by piepants - 2016-09-27, 03:27
RE: System Blue Not Working - by piepants - 2016-09-27, 06:06
RE: System Blue Not Working - by Tobi - 2016-09-27, 10:21
RE: System Blue Not Working - by tferoli - 2016-09-28, 18:38
RE: System Blue Not Working - by DnH2016 - 2016-09-29, 11:30
  Does the System Blue Basic take the same Firmware as System Blue? DrFX 3 52,103 2025-04-19, 23:25
Last Post: DrFX
