Low Pass Filter problems
(2016-10-20, 19:54)DrRobin Wrote: H-field question
I installed LP filters on H1 and H2, they are working great and set to 16kHz, they cut my noise from 60mV to 16mV.  However, I expected the thresholds to reduce, but they haven't, so whilst I have really low noise, I actually detect less signals as the signal peaks have been smoothed a little and now don't make the thresholds.
I am running in auto mode, should I be in manual and are there any suggested settings?
Hi Robin,
after adding 2 ICs to the H-field section I started in manual mode setting different values and settings followed always with hours of observation about the results. I never found a combination which was better than automatic setting. Once I disabled noise adaption, set to manual much lower values  (I have also very low noise here) but after some time I have seen that the threshold range was set automatically complete out of the range of the signal from one of the antennas.
So finally after a lot of experimenting I moved back to default and automatic mode. Mostly I'm on page 2 or 1 or maximum 3 refering to "Efficieny" and I'm happy with this.
If you also start with experiments take your time and maybe you have more luck. I'm interested in results!
Hartmut
73 de Hartmut / DK5LH
Stations: 1582
RE: Low Pass Filter problems - by elythomaslumber - 2016-10-21, 06:15
  Vin too low mt007 3 34,121 2016-12-04, 12:40
Last Post: allsorts
  Low gain on this system (Waregem) Noodweer Benelux 9 72,736 2015-07-18, 03:09
Last Post: JamesPatterson
  New station, very low stroke number Gianfran 2 28,931 2014-12-27, 09:47
  Low effectivity Snicker 13 107,029 2014-07-30, 21:24
Last Post: W3DRM
