H-Field antenna for system BLUE
Just throwing my experience out there - I'm in an urban area, but had the complete opposite results. My H-fields are often hopping between 800 and 2000 gain with a ~40-60mV noise floor, where my E-field is a consistent 6000 gain and 20mV noise. I had issues with massive interference on the H-fields a few weeks ago (with the signal also showing up on, but not triggering the E-field) but that seems to have gone away so I'm running all 3 antennas quite effectively.
The E-field is extremely easy to test if you have access to some quad shield coax with F-connectors (or can buy a short length) and a piece of wire. I had poor results with the PCB antenna, but a 10cm piece of 1.25mm2 enameled copper wire worked quite well.
Stations: 1614
RE: H-Field antenna for system BLUE - by piepants - 2016-10-21, 08:03
  Making a copper tubing H-field antenna Geewizard 3 20,765 2025-06-02, 18:02
  Blue e-field antenna question llowrey 2 22,461 2021-07-06, 14:34
Last Post: llowrey
  My E-field antenna setup TomVal 3 28,673 2020-11-05, 15:48
  blue ferrite / loop antenna connection? MTO-Mareuil 1 19,570 2020-10-20, 11:43
  GPS antenna SYSTEM BLUE ! IK1TTD 9 77,076 2020-06-03, 12:16
Last Post: GJ7DNI
