LED placement question
(2017-08-13, 16:10)SteveQlQ Wrote: Hi: almost finished with the build and no problems so far.
I have a question about the LED order. I know it really doesn't matter, but to be consistent with everyone else, which of the following is correct. I must add that I am somewhat red/green color blind: I can see a lit LED fine, but on a printed page...not so good.
On the front panel picture it appears as if this is the order is (starting L to R with Power)  R, G, G. Y, B, R, R
below that picture it shows the controller board with the order of R (on right of picture, would = Power on front panel), G, G, R, B, then whatever on the right of the front panel (Y,R or R,Y) . I know this is a silly question, but for consistencies sake, I thought it is worth it.
Steve
For what it's worth there are LED chips on the main board and I thought they should match the case LEDs. The board chip LEDs are R G G R B R Y which makes more sense as the signal LED shouldn't be a fault indicator.
Stations: 1888
LED placement question - by SteveQlQ - 2017-08-13, 16:10
RE: LED placement question - by JupiterJoe - 2017-08-13, 16:19
RE: LED placement question - by SteveQlQ - 2017-08-13, 16:56
RE: LED placement question - by SteveQlQ - 2017-08-13, 16:57
RE: LED placement question - by JupiterJoe - 2017-08-13, 18:34
RE: LED placement question - by Nekota - 2017-09-02, 20:08
RE: LED placement question - by cernese - 2018-02-04, 16:14
  fault led at first boot uvash 3 26,988 2021-11-18, 10:37
Last Post: aloha20
  Pre-Amp Placement StuartS 6 48,720 2019-06-11, 05:00
Last Post: Sleepypup
  Flashing networks led Alanpenwith 1 22,257 2018-09-14, 08:44
Last Post: Polyphemus
  Reboot and Only Power LED Jeffm5690 1 22,125 2017-03-07, 11:15
