Efficiency
#72
(2017-10-29, 10:17)orion_jb2001 Wrote: All interesting suggestions.  A question though on how the system puts together the signals to come up with a figure.  I too check on settings and what channels are being sent to the servers.  Now pardon a "newbie" question re efficiency I some times see current high efficiency with stations that appear to be only sending 1 channel.  Is that what happens with the system???? I would think that at a minimum a station should be sending channels 1A & 1B H fields to rate an efficiency, e fields channels a bonus.  My thoughts on the basics of this. Smile
For some stations, setting up the channels one at a time, is a better solution than trying to sort out the mish-mashs of signals on the graphs, when several channels are operating?
If stations are still sending good and useful signals at these times, then they should still be entitled to whatever result the server gives them?
Limiting the results by imposing false conditions may be contra-indicative of what is needed, i.e. if a station has good signals on certain channels and not so good on other channels, it appears to be a reasonable idea to self restrict which channels are sent, until the problems could be resolved.
Obviously sending on three channels, or more, if your situation allows is the optimum, but as we know, not all stations are in this good situation and we should accept some variations for the best of what these stations can do.
Brian. Idea Smile
