Efficiency
#97
Let me bring the general 'Cutty' suggestion back into focus, since it was generally outlined in two posts buried up above....
Just brainstorming: Big Grin
Suppose we explore this, for each unique station, as opposed to, or in addition to, station's relative "Network / Region" performance. This suggestion is for 'Typical" installations.  It's my belief that a second group might be considered, for example, those stat1ons that are 'purposefully' employed across regions or oceans. However they, I believe, should be
We define:
examples:
Efficiency = 200/1000=20%
Efficiency = 200/500=40%
Efficiency = 800/2500=32%
All stations would begin as group ONE, and then optimize for, and qualify for group TWO or THREE.  Actually, I think the server can do that automatically, since it already is capable of breaking strokes down by distance.d A 'quiet' group TWO station might not have as many 'signals' at high latitudes seasonally, but the 'noise signals' may remain essentially the same.... for a Group THREE, some adjustmen might need to be made seasonally, since 'theoretically' their 'local noise' soruces would remain at similar levels year round, while signal numbers rise and fall.
