(2018-09-15, 18:31)dupreezd Wrote:
(2018-09-15, 18:13)Michidragon Wrote:
(2018-09-14, 11:46)dupreezd Wrote: Michidragon, the way you specified your antennas on your BO station setup in not correct. Input 0 - 2 is for the H-Field. Leave Input 2 as "undefined" as you only have 2 ferrites.
Input 3 is for the E-Field.
Got it. changing it now....
EDIT: Done, let me know if that is correct?  I have 0,1 = H-field,  2 set 'undefined'  (for when/if I add a 3rd H-field) and now 3 is E-field. (I added the E-Field to my station last night.)
Yes, it is correct now, but is your E-Field really 3000mm (3m) long. It should only be 100mm
Now follow Cutty setup instructions. Smile
Whoops, no its 300mm/30cm. (Too long? Trimming that is sure easy enough..  I read that 10cm was a minimum, made it 30cm to make it easier to mount the PVC housing I put it in, to my mast. That said it can surely just be 10cm and sit in the same housing.)
RE: New member, having some problems with H-field big interference bursts.. - by michidragon - 2018-09-15, 19:22
  Fault mode after big electrostatic discharges. ant01n3 1 13,954 2024-01-30, 22:55
Last Post: dupreezd
  H field big difference in gain DrRobin 16 126,104 2016-10-19, 22:32
Last Post: allsorts
