Statistic page
(2021-08-31, 17:38)cutty Wrote:
(2021-08-31, 16:19)Szutek Wrote: Hello,
Statistics page for a couple of weeks now
  (https://www.blitzortung.org/en/station_list.php)
displays stored highest hourly results instead of last hour's results.
Is this an intended change?
Peter
Default "sort" is by "counter_used" (USED) column, "descending" ... which will always show stations / region with the highest 'used' count.
On some chosen page selections, or specific sort request, an "orphan" database from August 19th has a higher USED count then the current 'real-time' database, so the table, erroneously, lists those 'orphan' numbers ahead of others. They can be distinguised by the "last signal" date of "August 19", and usually a server name of "whateverRegionName 2" instead of ""whateverRegionName 1"
Issue is a tough one, but Egon's continuing to look at it, as far as I know,.
Additional info, and a hint, at this post, on the Operator's Internal forum:
https://forum.blitzortung.org/showthread...3#pid24203
Dear Cutty,
your comments did not leave me alone. I added a "current only" option. With this obtion, only stations are listed that were active in the last two hours.
Statistic page - by Szutek - 2021-08-31, 16:19
RE: Statistic page - by cutty - 2021-08-31, 17:38
RE: Statistic page - by Egon - 2021-09-02, 12:46
RE: Statistic page - by Szutek - 2021-10-05, 14:21
RE: Statistic page - by cutty - 2021-10-05, 17:09
