What Is The Best GPS Antenna/Unit in 2024
(2024-06-17, 09:20)Kets_One Wrote: Hi Schwab,
GPS system used by BO consists of two parts:
- GPS/GNSS antenna
- GPS controller (that does the necessary calculations)
Isn't the GPS controller integrated in the BLUE system board (with my BLUE mini board its integrated). This means you normally cannot swap it out for another.
For the antenna though, you can use a different one if you like. They are all connected using the SMA connector on the board.
Tom,
... the newer blues (  and the Blue Mini) should use highest baud, and our older Blues and Reds 115200.  I personally use GPS+Glonass with SBAS enabled  on my Blues, and Reds don't give me a choice of constellation, but , I do enable SBAS... since I normally have a GPS SBAS sat (133,134,135) in view.
It's not as critical now, since all signal time stamps are assigned by the receiving server, but it's important to keep that 1pps in sync.
I've stayed in the 'lower end' antennas, after experimenting with a few supposedly better one... didn't notice much difference... my issue is simply having them in location to view the largest constellation areas... location seems much more important than 'variety' or brand of antenna, at least for me. For the last month or so, my reception has been degraded compared to ongoing history.  My latest Blue (3020) has a LOT more GPS loss than the other three, and the antennas for each are in the same 18" area!
I've a GPS status page cobbed together here: https://sferics.us/GPSinfDat.html  which I refer to once in awhile...
RE: What Is The Best GPS Antenna/Unit in 2024 - by cutty - 2024-06-17, 20:42
  System Blue unit appears deaf station 2831 - SOLVED jonfear 1 17,365 2022-08-08, 11:58
Last Post: hazelnut
  GPS antenna SYSTEM BLUE ! IK1TTD 9 77,100 2020-06-03, 12:16
Last Post: GJ7DNI
  GPS antenna elythomaslumber 1 22,554 2017-05-29, 19:03
Last Post: Max_Headroom
