Nearby Power Lines
#18
I agree with Don.
300m away from me is a 440kV high-voltage line 988 and the receiver works well. I also think that the problem is a problem in some insulator. However, interference can pull the line and the insulator may be several miles away. Very well it can be found using the thermal imager.
Stations: 550, 988
RE: Nearby Power Lines - by W7DRM - 2014-08-20, 19:43
  E-Field Antenna and 60 Hz power lines waysta 4 41,176 2017-06-09, 23:11
Last Post: radiofarol
  NeB Q: Will nearby FM Radio Cell towers cause problems br1ght 2 29,233 2015-09-18, 20:53
Last Post: br1ght
