Low effectivity
On the controller by the RJ45 jack is a ground block. Just one ground. Controller only. Don't ground any other points. Make sure it's a good 'cold water' or earth ground. The controller ground is common to all the components in the system from that one connection. Assuming you've used shielded CA5/6 cable.
5 Feet is probably still too close to the computer... get those antennas and amps as far away as possible... 10m or so
Low effectivity - by Snicker - 2014-07-29, 12:12
RE: Low effectivity - by Egon - 2014-07-29, 22:41
RE: Low effectivity - by Snicker - 2014-07-30, 08:57
RE: Low effectivity - by Tobi - 2014-07-30, 10:09
RE: Low effectivity - by Snicker - 2014-07-30, 10:18
RE: Low effectivity - by MeteoCercal - 2014-07-30, 13:43
RE: Low effectivity - by Snicker - 2014-07-30, 14:31
RE: Low effectivity - by RichoAnd - 2014-07-30, 10:40
RE: Low effectivity - by Snicker - 2014-07-30, 10:46
RE: Low effectivity - by W7DRM - 2014-07-30, 21:24
RE: Low effectivity - by cutty - 2014-07-30, 14:37
RE: Low effectivity - by Jim.McMurry - 2014-07-30, 14:53
RE: Low effectivity - by Andrew.Instone-Cowie - 2014-07-30, 15:16
RE: Low effectivity - by Gerhard.Wittevee - 2014-07-30, 17:01
  Vin too low mt007 3 34,680 2016-12-04, 12:40
Last Post: allsorts
  Low Pass Filter problems DrRobin 14 102,938 2016-11-02, 22:04
Last Post: allsorts
  Low gain on this system (Waregem) Noodweer Benelux 9 73,925 2015-07-18, 03:09
Last Post: JamesPatterson
  New station, very low stroke number Gianfran 2 29,427 2014-12-27, 09:47
