Building a red system
(2014-10-26, 10:15)Cutty Wrote:
(2014-10-26, 07:22)Jack Zielke Wrote: everything I have read on the forum says I want air below the E-Field probe.
I think there are 3 easy places to put it.
The E field probe must be VERTICAL... and for best results, should be OUTSIDE, away from structures, and noise...
I really appreciate the help. For my specific situation I listed 3 locations and I was trying to weigh the differences for:
Total height above the ground
Total air space between the probe and ground
Total coax length
I should not have added the photo of the temporary location. That is as far as the coax would reach and I need to choose a final location so I can buy the right length. I did not realize that it would cause you to reply without reading the post. It also might cause others to make the same mistake and think it is a suggested location. I will remove it.
Thanks again for your help!
Stations: 1181
Building a red system - by Jack Zielke - 2014-10-09, 02:04
RE: Building a red system - by W7DRM - 2014-10-09, 04:19
RE: Building a red system - by Jack Zielke - 2014-10-09, 04:51
RE: Building a red system - by W7DRM - 2014-10-10, 16:02
RE: Building a red system - by Jack Zielke - 2014-10-26, 07:22
RE: Building a red system - by cutty - 2014-10-26, 10:15
RE: Building a red system - by Jack Zielke - 2014-10-26, 22:54
  Building a ferrite-rod antenna Kellogs 1 9,537 2025-04-09, 14:03
Last Post: Kellogs
  Is it possible to buy System Blue or can I make System RED myself? gadis 2 22,197 2025-01-06, 19:38
Last Post: mendip_defender
  Building a Blue - Optional SMA connectors? Mike6158 4 39,293 2017-04-09, 22:20
Last Post: RichoAnd
